ORIGINAL: JeffH
If I can't have the Tiger Tail .40(aka Bobcat) then I am all for a .40 sized Blue Angel.
While we are at it, I think somebody should laser scan an Atlanta, then reduce the size and CNC a plug!!!
Jeff,
if you have a TT40/Bobcat plan that you can share, I'd be happy to take a look at it.
As for the Atlanta, I'm not sure what you have in mind when you say a "laser scan". Are you thinking along the lines of digitizing the 3D model to then produce a scaled down plug? Whew! I won't go there as it has nothing to do with laser cut wood fuses. That said, I think it would be a wonderful project.
There may be an easier route to that though. I believe Zigsaw made a 40 size "Atlanta". If it wasn't Zigsaw it was IM and they made a very similar design. I want to say it was called something like an Omega but not quite as this last was a 60 size design. Now I remember, it was called a
Quatro.
David
