RE: Will I get interfearance with this ?
Your range will probably be lower. Try doing a range check. colapse the TX antenna, and walk away from the heli, engine not running of course, have a frend watch for when the servos stop functioning corectly, then try it again with the antenna in the normal position. if the distance is much less don't fly it that way.
