RCU Forums - View Single Post - Elevator Radio Set Up
Old 05-26-2013 | 04:22 AM
Rodney
Default RE: Elevator Radio Set Up
ORIGINAL: jester_s1
You can reverse a servo if you want. All you have to do is switch the two wires going to the motor. I don't have that radio, but if it allows you to set up a mix with either ch. 5 or 6 and one of them is available, you can do it that way also.
Wrong, you have to reverse the motor wires as said but you must also exchange the two outer wires on the feedback pot.
