ORIGINAL: flyinwalenda
Connect one elevator servo to the ELEVATOR port of the receiver. Connect the other elevator servo to the GEAR port of the receiver.
Program the following mixes. After programming the mix you may have to reverse either the Elev. or Gear servo and adjust the rates up or down to match.
Mix 1 – (This disables the Gear Switch on Transmitter, This also allows proper elevator to gear mixing… without this only the down side of servo works.)
Gear Mixed With Gear Activate
Rate Down -100% Up -100% (Important has to be negative values)
Switch On Trim Active
Mix 2 – (Mixing Gear Channel with Elevator for Dual Servo Elevator – Using less than 100% to match the surfaces in the down and up positions.)
Elevator Mixed With Gear Activate
Rate Down +96% Up +96%
Brian - Thanks for the help see my settings below but
I still have a problem (see below the pics) .
Using these settings both elevator halves are working but the one connected to gear is still not aligned and if I hit the gear switch 0 to 1 or 1 to 0 that elevator half still moves as if it was the Gear switch is still active.
I don't think that is correct and wondering how I resolve it?
