RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
Guijs,
do a process of simple elimination, one thing at a time to isolate the root cause:
- get rid of the fuel filter
- check fuel line for leaks, slipped off tubes in tank etc
- open the carb and clean it well
- if you can test with a different EI
The carb is the prime suspect, I also had a new DLE 20 that wouldn't start every now and then - tore my hair off until I found aluminum scrapings in the carb that were preventing the pump from drwaing fuel !
Gas engines are great, and the DLE 20 is super reliable, with a little patience you fill find what's wrong and then you will enjoy this great little engine
