RE: NEW DLE 20cc Gasser! (Data & Links 1st Post)
I have read that some ignitions will not do well with voltage over 6v. And NiMh batteries charge to over 6v - have read that some people drain the battery a bit to get it down to 6v. So when they're fully charged they might be causing an ignition miss. From the pros on this thread you only need 4.8v (as Fooped just mentioned). I use a seperate 4.8v NiMh and it works great. I'd recommend testing with that setup on the ground. It's also a very good idea to take your carb apart and inspect for gunk \ loose filings.
