RCU Forums - View Single Post - canopy frames?
Old 06-01-2013 | 09:23 AM
Avaiojet
Default RE: canopy frames?
ORIGINAL: Chad Veich
Or just build up the frames with primer and then paint. On many aircraft the glass is flush or nearly flush with the frames and thus they do not need to stand proud of the canopy very much if at all.
Chad,
I believe you are correct. A simple tape edge from a coat of paint is about the correct thickness. Anything else is probably overkill.
In my case with this model, I wanted the canopy exhagerated. All the features are a bit exhagerated. It's also CL.
Charles
