RCU Forums - View Single Post - tower hobbys 75 engine
Old 06-10-2013 | 05:00 PM
aspeed's Avatar
aspeed
Default RE: tower hobbys 75 engine
The brass shims can be from another motor if you can find one with a 26mm piston dia.  You may not need one if the head clearance is more than about .015", unless you are blowing plugs.  They are not really a gasket, but more of a shim as was mentioned. Different thicknesses will give different running characteristics, like idle, top end power, different nitro content etc.
