tower hobbys 75 engine
Old 06-08-2013 | 12:34 PM
rye
My Feedback: (10)
Default tower hobbys 75 engine
hi guys
a guy gave me a tower hobbys 75 and a 65 la motor today they are a little stiff so i am going to put new bearings in them.i got her taken down but cant get the sleeve out or pistion rod off i am soaking right now in wd40 any thing else i should do thanks rye
Old 06-08-2013 | 01:29 PM
PatrickCurry's Avatar
My Feedback: (20)
Default RE: tower hobbys 75 engine
Don't think you'll be putting new bearings in your 65LA.  Lot of times you can get the sleeve out by heating it with a heat gun.  I would soak the whole engine in glow fuel and see if that loosened things up before I went tearing the whole thing down.  If he was running them on fuel that contained castor oil, they're probably just all gummed up and if you heat them up, they'll loosen right up to where you can crank them.
Old 06-08-2013 | 02:43 PM
The 65LA is a nice engine and I would advise against taking it apart ... just soak it in fuel and it will loosen up.
I don't know much about the Tower. It may be a rebranded Magnum, which is hit or miss in terms of quality.
Old 06-08-2013 | 03:19 PM
blw's Avatar
blw
The Tower 75 is a keeper. Good quality. There's a reason you never see them for sale often.
Glow fuel is very good for unsticking old engines.
Old 06-08-2013 | 03:30 PM
rye
My Feedback: (10)
After looking close the 65 la is a OS with a bleeder carb I hate those couldn't get my 60 to run right lost a tiger on a die stick may deep 6 the la 65
Old 06-08-2013 | 03:35 PM
My Feedback: (327)
Sent you a PM.
Old 06-09-2013 | 09:44 AM
Sport_Pilot's Avatar
Just put it back together and soak in some fuel. No need to replace bearings, you may be worse off. Try it out first.
Old 06-09-2013 | 10:01 AM
rye
My Feedback: (10)
ok thanks i got the la65 redone and the 75 is soaking its lose now but ill let it sit another day before i put her back together and test run them,thanks for the help guys ,rye
Old 06-09-2013 | 01:48 PM
rye
My Feedback: (10)
hi
where can i get the gasket kit for the tower 75 ,and do i need to use both brass rings on the head thanks rye
http://www3.towerhobbies.com/cgi-bin...?&I=LXVH41&P=Z
Old 06-10-2013 | 12:38 PM
Brass rings? Most model engines don't even have a head gasket, there may be an aluminum shim but this is just to lower the compression ratio. The Tower engines were ABC and did not have rings.
Old 06-10-2013 | 05:00 PM
aspeed's Avatar
The brass shims can be from another motor if you can find one with a 26mm piston dia.  You may not need one if the head clearance is more than about .015", unless you are blowing plugs.  They are not really a gasket, but more of a shim as was mentioned. Different thicknesses will give different running characteristics, like idle, top end power, different nitro content etc.
