ORIGINAL: dszabo2 Mike
Thanks for the advice on the pin. I took the servo apart today and the hole in the case seemed to have a relatively good fit to the pin.
However when I manually rotated the servo arm with the case off I was able to see how the center pin deflects.
I was getting the same slop with the case off as when it is on.
Based on the fit into the case I cant imagine the pin being able to move at all. How deep the the pin engage the case??
I have $18 already invested in the repair and the case is another $7. That's more than half the cost of a new servo.
Dave
Please view the
photo of damaged pin sockets in the case tops and read the information on MG servo provided
post #3 above
Pin should be a tight fit into the case which is well documented with photos and information on shaft wear, under:
Hitec - HS-225MG & HS-5245MG "How to make a good servo a great servo
Much more information available under sub section:
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
