RCU Forums - View Single Post - weatronic door sequencing
Old 06-13-2013 | 03:16 PM
luv2flyrc's Avatar
luv2flyrc
Default RE: weatronic door sequencing
Hi Dave,
Sounds like you're on the right track. The curve will be a top hat, could be upright or inverted depending on the start position of the servo/ electronic valve.
I've attached a couple of screen shots of mine, these are from 2 different Hawk files, set up the way you want ( main doors closed with gear down)
It sounds like you may not have enough servo travel dialed in for the valve to be triggered by the back end of the curve. Does the green line indicating servo travel move all the way across your curve?
Mike
ID:	1891447   Click image for larger version
