RCU Forums - View Single Post - Can i save a rusted nitro motor?
Old 06-14-2013 | 02:17 PM
Edwin
Default RE: Can i save a rusted nitro motor?
I'm assuming you're a gearhead. I've freed up a lot of seized engines using the crockpot/antifreeze method. Set the pot on low, remove the glow plug and back plate, and dip it for about 8 hours. It cleans the engine too. Take the bearings out while hot, much easier. Heat the case up again to install the new bearings. I think that carb can be salvaged, just have to work at. Dont put any plastic parts in the antifreeze. Most of the time you can remove the plastic throttle arm (if you have one) and dip it in the pot with the rest of the engine. Like was said oil it up good when reassembling. I like to use marvel air tool oil.
Edwin
