<p class="MsoNormal" style="margin: 0cm 0cm 10pt"><b style="mso-bidi-font-weight: normal"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">
Schweighofer Alpha Jet Project (Part 10)</font></font></span>[/b]</p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font face="Calibri"><font size="3">Finally we were able to set all the puzzle parts together in the open area. Some minor grindings at the intake area have to be done next. As you can see in the picture are the control surfaces already covered with glass and ready for sealing.
</font></font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">This will be the tallness of the model when it will be on the undercarriage.</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"></p>
</p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Once again the technical specification:</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Scale: 1:2,58</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Fuselage length without Rudder: 4600 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Fuselage length with Rudder: 4653 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Fuselage width: 702 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Fuselage tallness without rudder: 673 mm</font></span></p>
<span style="font-size: small"><span lang="EN-GB" new="" style="line-height: 115%; font-family: ">Tallness of the model when standing on the undercarriage: 1627 mm
</span></span>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Wingspan: 3530 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Length of each wing: 1531 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Wing root: 1027 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Thickness of the wing at the root: 103 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Elevator wingspan: 1676 mm</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Wing profile: RG 15</font></span></p>
<span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">Elevator profile: NACA 009</font></span></p>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3">The next step will be to finish the basic surface, after this we can start making the details. In the meanwhile the team has decided Peter Glück has to do this part too.
</font></span>
</p><p class="MsoNormal" style="margin: 0cm 0cm 10pt"><span lang="EN-GB" style="color: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3">More information will follow.</font></span></p><p class="MsoNormal" style="margin: 0cm 0cm 10pt">
<span style="font-family: "><font size="3">Modellsport Schweighofer</font></span><span style="color: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
<font size="3">Wirtschaftspark 9 • 8530 Deutschlandsberg
</font>
<span style="color: #002060"><font size="3">[email protected]</font></span></span></p>
