RCU Forums - View Single Post - should the flywheel be able to turn...........
Old 09-23-2003 | 12:30 AM
muddyrover
Default should the flywheel be able to turn...........
Should the flywheel be able to spin without the engine shaft turning? My flywheel doesn't seem to be on tight enough I don't think because it can spin freely without the shaft turning. Unless its supposed to be able to.
WHen i turn the engine shaft the flywheel will spin. When I spin the flywheel it just spins freely and doesn't turn over the engine.
