RCU Forums - View Single Post - should the flywheel be able to turn...........
Old 09-23-2003 | 12:50 AM
NePats-Fan
Default RE: should the flywheel be able to turn...........
the flywheel is NOT supposed to turn independantly from the crank! Check the nut; also, check the brass collar that the flywheel is mounted on, it may be worn down from the flywheel being loose
