RCU Forums - View Single Post - which wheels
Thread: which wheels
Old 06-27-2013 | 06:40 AM
Planeclaims
Default RE: which wheels
If you don't mind spending a little extra, I highly recommend Tettra, available online @ Central Hobbies. I prefer Tettra because their larger sponge tires seem to last longer than other brands. They also roll the quietest. My Wind S Pro has the 60 mm nylon wheel w/sponge tire for the mains and the 25 mm aluminum wheel w/sponge tire for the tail. The tires are easily removable from their respective hub and can be flipped if they don't wear flat. The tail tire takes the most abuse, so it wears the quickest. Tettra also has replacement sponge tires that easily slip onto the hubs. I like this feature because I don't have to disturb the tiny tail wheel collet to flip or replace the sponge tire.
Steve
