RCU Forums - View Single Post - which wheels
Thread: which wheels
Old 07-01-2013 | 06:09 AM
woodie's Avatar
woodie
Default RE: which wheels
ORIGINAL: nonstoprc
Thanks everybody for sharing your thoughts. It seems there are many choices there.
I would love to give the MPI F3A [link=http://www.maxxprod.com/mpi/mpi-29.html]MPI F3A Wheels (AW57) [/link] a try. as it should help solve the broken hub problem for good. One thing not sure though is since the tire is made of foam, the plane could like to bounce on hard-surface runway. Any comment?
The foam tires won't make the plane 'bounce', they usually help absorb the 'impact' rather than bouncing like a ball on a hard surface. The landing gear is typically the culprit for causing the bounce if you drop one in a little hard, or are too hot on landing. And, if the gear is flexible/springy, that also contributes to the problem. I have found stiffer gear can make landings a little easier with less bounce/rebound. Kind of like a pole vaulter using a steel or stiff pole vs a very flexible pole. The flexible pole will bend further and help him clear a higher bar as it 'snaps' back to straight.
Woodie
