RCU Forums - View Single Post - New blog article: jet engine efflux protection for your electrical cables.
Old 07-01-2013 | 10:32 AM
olnico's Avatar
olnico
Default RE: New blog article: jet engine efflux protection for your electrical cables.
ORIGINAL: DrScoles
Thanks for the informative article. What is the safe temperature for a wiring loom to get to with regular servo wire? Is shielding it with heat blanket and foil adequate if you aren't worried about direct flame?
Well, there is no such thing as regular servo wire. It all depends of the wire gauge and type of insulation. You need to make a test with the servo wire you intend to use. Shielding with separate material can be adequate, but bare in mind that shielding is always as good as the weakest spot. If one zone is not properly covered, then shielding is useless. That's why I recommend using heat sleeves. The time you'll save wrapping around the cable and having a 100% heat and chemical proof shielding will largely make the price increase.
Have a look at this video:
[link=http://vimeo.com/69404938]Wrap around MIL spec sleeve demonstration.[/link]
