<p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><b style="mso-bidi-font-weight: normal"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Schweighofer Alpha Jet Project (Part 11)
</p></font></font></span>[/b]</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">As I’ve already written are now the tail surfaces ready for covering. I’ll explain the next steps which are done with the fuselage a little bit more detailed, maybe this could help you for your next moulds.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">If you sand the Styrofoam down to the wooden formers there’s always the risk of seeing them through the glass covering. To avoid this Peter mills away 1mm of the formers before levelling. Nad covering.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><a href="http://alphajet-projekt.at/content/teil11_07_big.jpg"><font face="Calibri" size="3">
</font></a>
</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><a href="http://alphajet-projekt.at/content/teil11_06_big.jpg"><font face="Calibri" size="3">
</font></a>
</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><a href="http://alphajet-projekt.at/content/teil11_05_big.jpg"><font face="Calibri" size="3">
</font></a>
</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><a href="http://alphajet-projekt.at/content/teil11_04_big.jpg"><font face="Calibri" size="3">
</font></a>
</span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">In the meanwhile all parts are ready covered and we can come to this result:
</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Until now Peter has used 50m² glass textile (213g/m²) and 14 kg of Epoxy adhesive for the building of the master model
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">From now on our Alpha Jet will be filled with normal body filler, this step takes a long time to achieve a good result.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">More information next week…
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">The building of the master model is almost finished and we had to decide which company gets the assignment to make the moulds and the models. After checking thoroughly all the possible companies we have decided to make our Alpha Jet with Paritech. Many of you will know this company, but I’ll use this opportunity to introduce this company.
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Company portrait Paritech
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Modelling as a hobby – this conducts Uwe Rihm sins his childhood and caused him to make his hobby to his profession.
</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Picture: paritech.de
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">In the year 1984 Uwe began to produce fuselages for most of the German model companies in hand laminating procedure. The large demand of the marked leaded to a business cooperation with his nephew Matthias Paul. Paul is also a modeller since his childhood, he was 7 times German junior champion.
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Since this time both work together as equal shareholder and technical supervisor for Üaritech GmbH.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">2004 Paritech started to produce recon drones. Due to the increasing space requirements Paritech relocated to the industrial Area of Herxheim near Landau.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Since 2010 Partitech is the first German model company with DIN EN ISO 9001 certificate, this allows the realization of Industrial orders.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">The highlights of the model palette of Paritec is the very large DG1000 S, Fox MDM-1, a Jodel Robin and the Viper MK II, the largest RC Viper worldwide.
</font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><font size="3"><font face="Calibri"><span lang="EN-GB" style="mso-ansi-language: EN-GB">Picture</span>: Bernhard Kager
</p></font></font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt">
</font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><font size="3"><font face="Calibri"><span lang="EN-GB" style="mso-ansi-language: EN-GB">Picture</span>: Udo Dettelbacher
</font></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Picture: Paritech.de
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">I think no other company could reach these quality standards. This is the reason we’ve decided to work together with Paritech for our Alpha Jet.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font face="Calibri" size="3">More information on </font>
<font face="Calibri" size="3">www.partitech.de</font>
<span style="FONT-FAMILY: "Calibri","sans-serif"; COLOR: #002060; mso-bidi-theme-font: minor-latin; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin"><font size="3">Modellsport Schweighofer</font></span><span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
<font face="Calibri" size="3">Wirtschaftspark 9 • 8530 Deutschlandsberg
</font></span>
<span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font face="Calibri" size="3">[email protected]</font></span><span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
</p></span></p>
