RE: YS 4 stroke break-in??
Bass, I have the same tach you do and under certain conditions I get those same exaggerated readings, however if I take the readings from the front of the prop they are correct. I know that is a no no. In the AM it will only read correctly from the back. It also seems to read black props better than gray ones.
