RCU Forums - View Single Post - YS CDI IGNITION BRAID
Old 07-07-2013 | 03:00 PM
MTK
Default RE: YS CDI IGNITION BRAID
ORIGINAL: drac1
Hi guys,
I noticed the braid on the plug lead is coming out from the plug cap. I have seen on pictures, some have a semi clear wrap of some sort around this, which i presume is to stop this from happening?
Is this a heat proof tape that is used or if not can someone advise what they have used?
Any advise is appreciated.
Scott
In general, the braid is copper based and the plug cap is steel. You can push the braid back in and drop a drop of solder on the edge where the two come together. Use a tie wrap or wire tie to get the braid small evenly. No need to solder all around, but it wouldn't hurt anything if you did. A shrink tube works fine covering the area as does electrician's mastic tape (it's rubber tape that you stretch to make it adhere to itself). There is also spiral cut tubing that is designed as chafe guard, but use that over the shrink tube or mastic
Good luck
