<p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><b style="mso-bidi-font-weight: normal"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Schweighofer Alpha Jet Project (Part 12)
</p></font></font></span>[/b]</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">All the parts of our Alpha Jet are now covered with glass, sanded and filled. With this method all roughness can be removed and all edges are defined in this way.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt">
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB">
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">You can plan everything in theory but the reality shows where the way leads. The problem with the wings is the outline with all the buckles and interruptions which causes different profile widths.
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Here you can see Peters armada of sanding tools. Without these tools a flat sanding of the large wings would not be possible.
</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Again and again the lines have to be checked. For this Peter has this levelling board.
</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">The exact planning of Peter made it easier to assemble the elevator. The box is built of CNC milled parts and is dowelled to the elevator base with 8mm wooden dowels. Thereby all the angles fit and the screwing is more precise and easier.
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">For all theorists some adjustment values:
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">anhedral wings: 6 degree per wing
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">anhedral elevator: 8 degree per elevator
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">angle wing: 0,5 degree
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">angle elevator: 0 degree
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">This stage of the building is very complex and needs more time Peter has thought. After all the parts are finished Peter will settle to the painting cabin.
<span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Calibri","sans-serif"; COLOR: #002060; FONT-SIZE: 11pt; mso-ansi-language: DE-AT; mso-bidi-theme-font: minor-latin; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Modellsport Schweighofer</span><span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Calibri","sans-serif"; COLOR: #002060; FONT-SIZE: 11pt; mso-ansi-language: DE-AT; mso-bidi-theme-font: minor-latin; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">
Wirtschaftspark 9 • 8530 Deutschlandsberg
</span><span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Calibri","sans-serif"; FONT-SIZE: 11pt; mso-ansi-language: DE-AT; mso-bidi-font-family: "Times New Roman"; mso-bidi-theme-font: minor-bidi; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">
<span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">[email protected]</span></span>
