RE: GAS/GLOW HOW TO....
Tygon seems to work fine. Viton is better but very expensive. Even that little bit of nitro should help with throttle transition and in keeping the glow plug lit. Probably a touch of power added as well.
There are three different fuel pump diaphragms available, and either the brown one or the blue acetate ones work fine; avoid the black one. As for the regulator diaphragm, as far as I know the only one available is the black one. I remove the fuel, fuel up with a mixture of Coleman fuel and 20:1 oil, and run the engine briefly before storing the plane. (Leave that mixture in the tank.) When you go to fly again, remove the "storage fuel", fuel up with the Gas/Glow mix, and you're good to go.
AV8TOR
