RCU Forums - View Single Post - Tiny Curare
Thread: Tiny Curare
Old 07-10-2013 | 11:23 AM
ehsanmorshedi
Default RE: Tiny Curare
wing pannel is now ready for skin. To prevent any distortion of the wing during glueing the skin a jig must hold the structure butusually don't use the common jig in this size. I simply use 2 thick sheets of balsa attached to the wing with some pins. one sheet to the L.E and 1 to T.E. the picture attached shows this better than any word. I used 1mm balsa (1/32) to skin the wing. first I glue it from the front edge with some C.A. then the entire skin joints the ribs with epoxy resin. I guess skinnig the wing will be finished in the next 2 days.
Ehsan
ID:	1899206   Click image for larger version
ID:	1899207   Click image for larger version
ID:	1899208   Click image for larger version
