RCU Forums - View Single Post - Modellsport Schweighofer Alpha Jet Project
Old 07-12-2013 | 12:10 AM
  #31
Default RE: Modellsport Schweighofer Alpha Jet Project
<p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><b style="mso-bidi-font-weight: normal"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Schweighofer Alpha Jet Project (Part 13)
</p></font></font></span>[/b]</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Not everything works perfect…
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Peter was a little bit too motivated while sanding the fuselage on some points and sanded the cover down to the foam on some points. To repair these points he had to cut out the glass and he had to cover and fill these areas again. Work which takes long and delays the project.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB">
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">As you can see on these pictures we have good news as well. The Alpha Jet slowly gets its final surface and already looks edged. Time is short and the Alpha Jet has to go to the painting cabin. Peter had to do many overtime hours to catch the timetable.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Our Alpha Jet has many edges and corners. For applying the filler Peter uses one way injections. The drawing is done with his fingers or suitable tubes.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">The last pictures for today – peters sanding tube for concaved areas. Until now we have uses 16 kg of filler and many meters of sanding paper.
<font face="Calibri" size="3"> </font></p></span></p><span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Calibri","sans-serif"; COLOR: #002060; FONT-SIZE: 11pt; mso-ansi-language: DE-AT; mso-bidi-theme-font: minor-latin; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">Modellsport Schweighofer</span><span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Calibri","sans-serif"; COLOR: #002060; FONT-SIZE: 11pt; mso-ansi-language: DE-AT; mso-bidi-theme-font: minor-latin; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-fareast-language: EN-US; mso-bidi-language: AR-SA">
Wirtschaftspark 9 • 8530 Deutschlandsberg
</span><span style="LINE-HEIGHT: 115%; FONT-FAMILY: "Calibri","sans-serif"; FONT-SIZE: 11pt; mso-ansi-language: DE-AT; mso-bidi-font-family: "Times New Roman"; mso-bidi-theme-font: minor-bidi; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">[email protected]</span></span>
