RCU Forums - View Single Post - Balsa USA Enforcer Build...
Old 07-15-2013 | 07:19 AM
ser00
Default RE: Balsa USA Enforcer Build...
One thing that I have to say about the kit so far is that the die-cutting on this particular kit (meaning this box / this kit only) is horrible. It seems to be more die-crushing than anything else. The biggest complaint is that the cut does not go all the way through the wood. This is not that much of an issue on the balsa because I can sand the back of the balsa to help pop it out, but it is very difficult to do this with the plywood parts (fuselage sides, etc). Overall, not a big issue. I will just need to be extra careful in removing the parts and carefully (gently) sand those pieces that have some roughness to them or little balsa "hangers" on them.
