RE: Surging on Acceleration (again)
One more question:
I have a suspicion compressor efficiency is down causing compressor stall on these older engines. Is it possible erosion has etched away compressor shroud contour opening a gap and causing inefficiency? If so, is it possible to re-shim the compressor closer to the contour and if so, how?
I really have a suspicion this would fix this problem.
Mitch
