RCU Forums - View Single Post - Candy Kane Build Thread
Old 07-17-2013 | 05:32 PM
sahartman21
Default RE: Candy Kane Build Thread
Trim off the outside edge of the vacuum bag to remove the caulking prior to separating the wing from the peel ply.
Make sure the epoxy is fully dry and not tacky before separating the layers of fabric.
I used a sanding block to trim the excess fiberglass cloth from the edges.
The surface of the wing was later lightly sanded with some 220 grit paper on a sanding block.
ID:	1901666   Click image for larger version
ID:	1901667   Click image for larger version
ID:	1901668   Click image for larger version
