RE: cutting matts foam planes
You are misunderstanding the tool I think ? You trace out your foam plane on your foam with a marker, then you trace/cut that line with this tool , it cuts squares edges just to the depth of your foam thickness, that way it doesn't dig deep in your cutting surface beneath.
it will really make cutting out foamies slick. Especially the straight edges since you can use a ruler with it.
