RCU Forums - View Single Post - Tamiya Speed Controllers
Old 07-19-2013 | 11:17 AM
Panzerpaul's Avatar
Panzerpaul
Default Tamiya Speed Controllers
Gentlemen:
Can any of you tell me the difference between the Tamiya TEU-105BK and the Tamiya TEU-104BK speed controllers?
Comparing the manuals doesn't help much but the obvious difference in the pictures is that the 105BK does NOT have a plug to go into the RC receiver battery slot....whereas the 104BK does.
If this is the only difference am I to assume that I will need a seperate battery supply for the RC receiver if I use a 105BK controller?
And if that is the case.........then is there any reason NOT to use the 104BK and just run the RC receiver off the 7.2v battery supply as seems to be the case because the 104BK has such a plug?
I intend to use one of these to operate an RC armored car because they are so small.
Thanks Paul
