RCU Forums - View Single Post - Jeti Master Mezon 95 question: Need Help!!!!
Old 07-23-2013 | 07:25 AM
namancheno
Default Jeti Master Mezon 95 question: Need Help!!!!
Hope that someone can help me. Have the following question:
I have two Jeti Master Mezon 95 with the same identical setup: Q80 13XS + Falcon 20.5x14 + same Th curve + same ESC settings and same End points.
One is 67A and consumes around 500 mAh more and the other one is 47A and consumes less mAh per flight [X(]
Both are giving me at max TH around 6750 to 6900 rpm depending on the battery pack.
Why is this happening? How can I fix this?
Thank you,
Ney
