RCU Forums - View Single Post - glow plug adapter for gas/glow conv.
Old 07-23-2013 | 08:57 PM
Scota4570
Default RE: glow plug adapter for gas/glow conv.
I was interested in the glowplug, but using in a conversion or ready made gasser. Not so much interested in running a small engine this way. If one used a glow plug adapter to use this plug, what are the chances is would run well. Timing would be controlled by compression. Would the timing be too retarded to get any decent power on most gassers? I have an OPS 30 that I made a new head disk for a sparkplug. It is a fine engine. The head disk is easy to make. I could vary the compression to get the timing right. Would such an engine run at too low a temperature to keep the special Enya plug lit??
