RCU Forums - View Single Post - Modellsport Schweighofer Alpha Jet Project
Old 07-23-2013 | 11:18 PM
  #36
Default RE: Modellsport Schweighofer Alpha Jet Project
<p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><b style="mso-bidi-font-weight: normal"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Schweighofer Alpha Jet Project (Part 17)
</p></font></font></span>[/b]</p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">In the meanwhile the second side is finished. We are completely satisfied with the result. The winding of the adjusting pins are drilled out with 6mm, then the pins of the second side are fixed with 6mm screws.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="mso-ansi-language: EN-GB"><font size="3"><font face="Calibri">Demolding has worked fine the master model has survived the process without being damaged.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">Now it’s time to make the first nose cone.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">First the moulds are being waxed and brushed with a special pasty resin. This one is not for flying we need this cone for making another mould. The part of the series is made of complete other material and techniques. We’ll place pictures of these techniques later.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">After a curing time of 1 day the next 3 layer 165 glass are laminated, then the connecting area has the correct thickness.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">Now both halves are screwed together.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">After 2 days curing time the edge is cut with a sharp knife.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">Now the nose cone can be dismoulded.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">During the curing times Peter has finished the fuselage so far that he can begin with the detailing. He has spent many hours with sanding. Here you can see the tail part of the fuselage which is blacked with contrast powder.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">The powder is rubbed on the parts with a sponge. During sanding with 600 paper small scratches and holes get visible much better. Now Peter has to sand as long as all of these holes and scratched are removed. On the picture you can see Peter’s favourite grinding machine which is used with papers above K120.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">Finally after detailing The parts are sandes again with 1200 paper and then they are polished.
</p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">More information will follow.
</p></font></font></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span lang="EN-GB" style="COLOR: #002060; mso-ansi-language: EN-GB; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font size="3"><font face="Calibri">I wish you all a good week and thank you for the good feedback on our project.
<font face="Calibri" size="3"> </font></p></span></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 10pt"><span style="FONT-FAMILY: "Calibri","sans-serif"; COLOR: #002060; mso-bidi-theme-font: minor-latin; mso-ascii-theme-font: minor-latin; mso-hansi-theme-font: minor-latin"><font size="3">Modellsport Schweighofer</font></span><span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
<font face="Calibri" size="3">Wirtschaftspark 9 • 8530 Deutschlandsberg
</font></span><span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin"><font face="Calibri" size="3">[email protected]</font></span><span class="MsoHyperlink"><span style="COLOR: #002060; mso-bidi-font-family: Calibri; mso-bidi-theme-font: minor-latin">
</p></span></span></p>
