RCU Forums - View Single Post - Jeti Master Mezon 95 question: Need Help!!!!
Old 07-24-2013 | 02:47 PM
namancheno
Default RE: Jeti Master Mezon 95 question: Need Help!!!!
Rune, Brian and Bo:
Thank you for your replies. Did a check on the ESC connectors did not find any problems. I tested changing ESC from one airplane to the other and the result was the same. Tested Both ESC with a brand new TP 5400 G8 with 6 break-in flight and manage to get 69A and 59A but RPM the same around 6900rpm on both ESCs.
Bo both of my Master Mezon 95 are with the 1.27 firmware. I used both on my Spark Evo I airplanes with the same prop Falcon V2 20.5x14.5 with the same End Points 100% 100% and same Th curve 100% low side and 90% high side.
That is what´s driving me crazy same exact setup on both but one has more Amps and consume more mAh per flight. []
Here are some pics of the meseurments I did with my Jeti box.
Ney
ID:	1903627   Click image for larger version
ID:	1903628   Click image for larger version
ID:	1903629   Click image for larger version
ID:	1903630   Click image for larger version
ID:	1903631   Click image for larger version
ID:	1903632   Click image for larger version
