RCU Forums - View Single Post - Capiche 50?
Thread: Capiche 50?
Old 09-24-2003 | 04:31 AM
Cactus.'s Avatar
Cactus.
Default RE: Capiche 50?
Nathan, it might be easier to ask how much sky you want to use?
the Hype ect will use much less space doing it's thing than the Capiche which likes to be flown in big smooth pattern type style ( to get the best from it ) however it's tricking me because it's so lightly loaded it'll fly in a small space too ( still not hype small space tho ) you can be caught out trying to fly it like a Limbo Dancer.
if you wanted to compair it to other planes that like to be flown in the same manner ( but can't touch the Capiche ) the Acrowot, Balsa Nova, and Seduction would be good comparisons.
i can't see there not being a FF wing for the Capiche even tho work is on the 140 because there are lots of people asking for one, if i don't design my own first and if i did i'd probably go with a hypeish wing grafed to fit anyway. Then it'll do all you ask.
but for now, don't get the Capiche if you want to be hovering over the patch into a slight wind, pop into prophang and torque roll around the patch, leave that for Hypes and Cougars.
The Capiche is big open 3D and pattern.
