RCU Forums - View Single Post - Jeti Master Mezon 95 question: Need Help!!!!
Old 07-25-2013 | 12:43 AM
Rune
Default RE: Jeti Master Mezon 95 question: Need Help!!!!
I have the 13xs in the same plane as you and on a flight with P13 in almost no wind yesterday I used about 3200 Mah.
I know there has been (here in Norway) one 14xs that has it magnets slightly out off posistion tha one used about 70 A if I recall correct.but the numbers you are refering to cant be correct,
I would try to use a clamp A meter to see what you get , but if you are happy with the power and nothing else than your reading is making you worry I would fly.
