RE: Battery charging problems
It could be, or what's more likely is you have a bad connector. If you have an electrical multimeter (a cheap one is fine) check each cell voltage through the balance tap. If they are all ok, then do continuity checks with your connector. If it checks out, then there's a fault in the charger itself.
