RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 07-25-2013 | 07:22 AM
  #1771
RC_Fanatic
Default RE: Venus II
ORIGINAL: wildwillie3
The problem with mine was the bolt holes in the landing have to much clearance for the bolts. You can adjust it but after flying it with the vibrations from the motor they always go back to the way they were. It tracks on the ground fine but it wears out the wheels on pavement. I have left it alone for a couple of seasons now and haven't had any problems.
Bill
Thanks for the guidance on the gear, guys. I did notice some of the planes shown in this thread had as much toe-out as mine. A solution I've used to the bolt holes being too large is to epoxy in a small piece of aluminum, or even hardwood, between the legs in the center where there is a gap. Did that on my Focus Sport when I got it, but went to larger tight-fitting bolts when I redid the gear.
