RE: Mach 1
I'm pretty sure this is a Mach 1. The fuselage was just never sanded using the templates. As some of you guys may recall the fuselage was one big heavy block before sanding. The wing threw me for a minute. The Mach 1 wing has a tapered trailing edge with a straight leading edge. It is a little hard to tell in this picture. The canopy is an obvious switch.
