woodscra
I’m not sure of all the models Lanier RC, or AeroWorks are coming out with. Give these guys a call and I’m sure they will fill you in. All I know is that they will be ARF type aircraft. Right now you can order a 33% Edge 540T ARF from AeroWorks which they are shipping, and a 33% Extra 330L ARF which they are taking orders for. A friend flew his AeroWorks 33% Edge 540T ARF this weekend and it was great. It is powered by a 3W-100, which has plenty of power. I put the third flight on it and all I can say is I’m having a hard time keeping the Visa card at home.
If your into the kit thing you might want to check out AeroWorks and Carden Aircraft. Carden has 26%, 30%, 35%, and 40% Extra 330S kits at reasonable prices. However, their 540 Edge kits are a little on the pricey side.
As for the trailer, make sure you get a light duty axle. Tell the trailer manufacturer you will only be carrying around 150 lbs. That way they can install a light duty set of springs. The trailer will not bounce the heck out of your equipment with the light springs and it will not wonder when being towed.
