RE: Gyros
here's my setup: hk phazer kx arf version
- dx6i in normal mode (no mixing, elevon inh) as instructed by gyro manual. servo reverse switch all in normal mode
- hk orange rx 3axis flight stabilizer w/ built in dsm2 rx (all dip switch in normal mode except delta switch)
- left servo in ail-L slot
- right servo on elev slot
- esc on throttle slot
on this set up, elevon works perfectly when controlled vi tx but gyro will do the ff:
- when nose down, gyro will do elevator up, on nose up, gyro will elevator down. this is correct
- when roll to left, gyro will also roll to left instead of the other way, same with roll to right, gyro will roll to right.
- when dip swith of aileron was put to reverse, when roll to left, both control surface will elevate up by gyro, when roll to right, gyro will elevate down both control surface.
when i reverse my ail/elev on tx, aileron will be elevator and elevator will be aileron.
so what am i doing wrong
<br type="_moz" />
