RCU Forums - View Single Post - Modellsport Schweighofer Alpha Jet Project
Old 08-01-2013 | 10:37 PM
  #38
Default RE: Modellsport Schweighofer Alpha Jet Project
<div style="margin: 0cm 0cm 10pt">Schweighofer Alpha Jet Project (Part 19)</div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">As promised here&rsquo;s the video of the retract sequence:
[youtube]http://www.youtube.com/watch?v=AXiuz4XFlaE&amp;feature=player_embedded[/youtube]</span></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">&lt;iframe height="360" src="http://www.youtube.com/embed/AXiuz4XFlaE?feature=player_embedded" frameborder="0" width="640" allowfullscreen=""></iframe&gt;</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">In the meanwhile Peter Gl&uuml;ck has started detailing the fuselage. Before this I&rsquo;ll tell you about the last works on the nose cone:</span></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">Here you can see the preparations for the nose cone:</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">Now filler is attached to the fuselage and the nose cone is pressed against the fuselage until the filler is dried. Now the cone is disassembled, here you can see the result:</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">Now the finished cone can be pushed onto the fuselage it fits perfect!</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">The fuselage is ready detailed. The most work is to mark the correct positions.</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">After marking the detailing process can begin. More than 1000 rivets have to be scratched into the model. We had the chance to check the surface of the original very well at our Red Bull visit. The Alpha jet has no heightened areas, for this the planking with metal sheets is not necessary.</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">We have finished the fuselage!!!</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">Peter Gl&uuml;ck has worked more than 18 hours per day with the Alpha Jet, but the bigger part is already done.</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">We have a very tense time line and we get under pressure to catch our deadline. For this reason the fuselage was picked up and is on the way to Uwe Riehm (Paritech). Uwe confirmed the deadline for the jetpower fair can be catched if he gets all the parts until next week. I guess the wings still will be wet when we stick the parts together at the fair.</span></div><div style="margin: 0cm 0cm 10pt"></div><div style="margin: 0cm 0cm 10pt"><span style="color: #002060">Modellsport Schweighofer</span><span style="color: #002060">
Wirtschaftspark 9 &bull; 8530 Deutschlandsberg
</span><span style="color: #002060">[email protected]</span></div>
