Originally Posted by
kork
I am building this plane now and looking for some input, does anyone have pictures of this plane with a gas engine it? I have 3 options for a power plant- Jba 15cc, dle 20 or a os 91 2 stoke all engines have pitts mufflers on them. My concern is cooling the gas engines down. I think I would need to cut so much of the cowl do to this it would look awkward. If I use the os I would have to deal with the slime. Either way, I am at a point with the build that I need to decide* on what to use, Preferable gas?
Jason
The OS 91 2 stroke would work great I'm running a .75 Super Tigre. If you are worried about the the fit why not try on of those new Evolution gassers? The are the same size as a glow but are all gas engine the only difference you can see is the plug, a slightly larger carb, and the pickup for the ignition timing.
