Just consider the additional weight the aluminum adds over Plastic, otherwise adding some stronger parts up front never hurts. Bent a MM and busted two spinners myself. Just make sure to rebalance after adding the metal to the nose, you may need to add some to the tail. If you want some real mods, put a power 25 on the nose, it should take off vertical with that!
The P25 uses the same ESC I think, will need to check mine for sure, and the 3S 3300 mah packs. It wont fly as long, but it will scoot pretty good.
