RE: ultra stick crow setting obstacle
Think I would leave it like it is....not sure I would want full flaps and air brakes while at full throttle.......
I have had 3 US and all used the programming for the 8U. Worked like a charm......
If you are hell bent on doing it....just set up another mix and assign it to a different switch. Then you can test it both ways......
Pugs
