 ultra stick crow setting obstacle >
Old 09-24-2003 | 12:38 AM
Default ultra stick crow setting obstacle
To all H9 ultra sticks owners that uses the quad flap set up. I have everything programmed almost perfect on my 8u .Theres one small problem I cant overcome.I"m trying to get my the crow function to work on switch ( pre sets position only)without throttle movement interfering.What is happening is when i flip the switch for crow and throttle is full back,flaps and aileron are fully deployed,when i give some power they move with the throttle stick.I want a set up where the flaps and aileron dont move at all with throttle movement.Can someone help with this situation.I
Old 09-24-2003 | 09:40 AM
DownSideUp's Avatar
Default RE: ultra stick crow setting obstacle
This problem is going to be in your radio setup. All radios are different. I have only programmed quad flaps on a Futaba T6XA, so that's all I am familiar with.
Old 09-24-2003 | 10:35 AM
My Feedback: (14)
The answer to your question can be found at the GreatPlanes website under FAq's..programming the 8U for a quad flap wing, written by Ann Marie Cross.
Old 09-24-2003 | 01:27 PM
My Feedback: (15)
Think I would leave it like it is....not sure I would want full flaps and air brakes while at full throttle.......
I have had 3 US and all used the programming for the 8U. Worked like a charm......
If you are hell bent on doing it....just set up another mix and assign it to a different switch. Then you can test it both ways......
Pugs
