Keep an eye on your motor tabs. Generally it is a really bad idea to mount a da 50 as you have it. The tabs will crack and break off. It is just a matter of time. If you want vibration dampening mout a piece of ply with the dampeners to the fuse then mount the the motor to the plywood with shorter standoffs.
