RCU Forums - View Single Post - BJCraft BISIDE
Old 08-14-2013 | 08:38 AM
  #152
g_mkoch
Originally Posted by rcpattern
You're right. I got it backwards. Sorry about that. I am running the exact setup you mention g_moch. What I do is have my Tech aero regulator set for 6.8V. The BEC on the Mezon is set for 6.2V. You could easily reverse these so that the BEC is primary and the PLR5 is the backup. You can check in the ESC after a flight with a Jeti Box whether or not it had to draw from the BEC. I have turned on only the BEC side to verify it works, and it works great, but I like having the redundancy and a way to tell if it was ever used.
Arch
Basic ser up would be a PLR5 set to 6.8 volts while the BEC is set to 6.2 to draw current from the PLR5.
Is there any issue with one being linear and the other switching regulator?
