RCU Forums - View Single Post - Hype 3D Elevator Linkage
Old 09-24-2003 | 06:07 PM
schroedm's Avatar
schroedm
Default Hype 3D Elevator Linkage
Anyone out there done anything other than the closed loop set up on the Hype 3D?
Does the closed loop work well enough and positively enough?
Anyone using a pushrod idea?
I'm not keen on cutting into the rear of the fuselage and mounting standard sized servos as I think the strength will be compromised. Neither do I think mini servos will stand the test of time on the elveators.
Any thoughts/info?
