RCU Forums - View Single Post - Venus II
Thread: Venus II
Old 08-19-2013 | 02:13 PM
  #1774
RC_Fanatic
Originally Posted by tele1974
I have a question. After reading triangulation trimming and talking with Bryan Hebert I am convinced that the Venus would benefit an increase in positive wing incidence on the main wing. My question is, "How should I do it?"
All it needs is 3/32s on the trailing edge and that would get the wing at the .75 positive reccommended. Problem is the wing is supported along its entire chord by the fuse. Any suggestions would be great help.
Hmm. I wonder if that is my problem. I have to carry about 1/8" up-elevator trim to fly level. Someone here suggested I needed to move the CG back but, wonder of wonders, as I added tail weight, the elevator trim position did not change. I went to almost 3/4" back from the recommended CG. The trim stayed the same but the plane became a challenge to fly, especially when landing after I burned off some fuel. (The tank is in the stock position.). Why did you feel you needed the incidence change and did the shimming help? Thanks.
